Hello Guest it is November 26, 2026, 05:54:18 PM
Author Topic: VB macro runs when regenergating path  (Read 8461 times)
« on: October 09, 2013, 09:15:22 PM »
Hello,
I have a macro that has some JogOn commands called by my Gcode, each time I edit the Gcode and close/save it Mach3 regenerates the path and the macro runs, moving the tool around, but since the previous Gcode did not actually execute, it was just scanned for the path regen, the macro does weird/bad stuff.
Is there a way to inhibit the macro when the Gcode is just being scanned to regenerate the path? Is there a way to inhibit path regeneration?
Hobie
Re: VB macro runs when regenergating path
« Reply #1 on: October 09, 2013, 09:53:18 PM »
Try general config. Ignore M calls when loading.
« Reply #2 on: October 10, 2013, 10:38:53 AM »
Thanks Brett,
That did it!
« Reply #3 on: October 10, 2013, 11:13:19 AM »
It's Hoods fault, you can blame him.  ;D
