Hello Guest it is September 29, 2026, 04:44:44 PM
Author Topic: H-Bot + Mach3, is it possible?  (Read 12909 times)
« on: October 08, 2013, 05:13:17 PM »
Do you think it is possible to program Mach3 to work in an H-Bot style configurations?
http://www.edn.com/electronics-blogs/mechatronics-in-design/4368079/So-you-want-to-build-an-H-bot-
Re: H-Bot + Mach3, is it possible?
« Reply #1 on: October 08, 2013, 05:44:07 PM »
A better link/drawings.  Exact same concept:
http://corexy.com/theory.html
  •  9,374 9,374
« Reply #2 on: October 09, 2013, 01:30:54 AM »
It is certainly possible but most existing CAD/CAM software (which produces the necessary GCode) would program separate X and Y movements so you would probably have to write your own CAD/CAM software to take advantage of the 'same direction' / 'opposite direction', combined X-Y stepper rotations.
I don't really see any advantage to using the H-Bot configuration as opposed to conventional X - Y movement but perhaps there is one.
« Reply #3 on: October 09, 2013, 09:35:40 AM »
MeshCAM and Slic3r dont do that kind of interpretation.  This is something I would expect the controlling software/firmware to take care of.
In my case the H-Bot has huge advantages. Hot compartment for 3D printing.  Steppers don't like to function in 100C environments.
As far as Mach3 goes... I found the "formula axis correction" which makes me think it is possible.  But I can not seem to get it to run. Even a simple X+1 function does not seem to effect jogging. Looks like I might have to use an Arduino as an in-line mixer to do the necessary math.  I hate putting extra stuff in my control path. :-(
« Reply #4 on: October 11, 2013, 04:45:12 PM »
Any one?
