Hello
Guest
it is
October 12, 2026, 12:52:09 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Galil
(Moderators:
smurph
kcrouch
Amp enable pins
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Amp enable pins (Read 12371 times)
john15
24
Amp enable pins
on:
October 07, 2013, 10:06:13 AM »
Hi all
I am trying to set up a 2160 with 1900ICM and the plugin
DC servo's on an old Bridgeport interact, Bosch Z15 servo amps.
Do I use the normal galil ampen,xyz pins for enable or use output pins 1,2 and 3
John
Logged
Mad rush on a treadmill gets nowere
smurph
1,575
"That there... that's an RV."
Re: Amp enable pins
Reply #1 on:
October 27, 2013, 02:15:24 PM »
The Galil controls the amp enable vial the SH and MO commands. This is the ONLY thing that will drive those. The plguin issues SH and MO appropriately. However, if you want to control the enable of your amps directly from Mach, you will need to use output and map the mach enable signals to them.
Steve
Logged
john15
24
Re: Amp enable pins
Reply #2 on:
October 29, 2013, 11:10:59 AM »
Thanks. That makes sence
Logged
Print
Pages:
1
Go Up
« previous
next »
