Hello
Guest
it is
November 22, 2026, 07:16:15 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Activation file?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Activation file? (Read 10572 times)
jimglass
26
Activation file?
on:
October 07, 2013, 09:32:29 AM »
I purchased Mach3 on a CD. What is the file name that needs to be copied from the CD to Mach3 to activate?
Thanks Jim
Jeff_Birt
1,107
Re: Activation file?
Reply #1 on:
October 07, 2013, 10:11:59 AM »
If you got a legit license there should be a Mach1Lic.dat file. Copy that to C:\mach3. If you got your copy of Mcah3 as part of a machine package imported from the far East then you might have a pirated copy. Go to Help->About and see what Mach tells you about the license. If you got the license from a legit OEM you might see OEM_Name######, where the numbers are a serial number.
Happy machining , Jeff Birt
Check out
www.soigeneris.com
jimglass
26
Reply #2 on:
October 07, 2013, 10:31:53 AM »
Thanks Jeff
This is a legitimate license purchased directly from Art soft.
Let me try this.
Jim
Jeff_Birt
1,107
Reply #3 on:
October 07, 2013, 10:37:25 AM »
ArtSoft should have emailed you the license file then. The license file may also have a number after the .dat, i.e. Mach1Lic.dat.######. You can strip the number off or leave it, Mach will recognize it either way.
Check out
www.soigeneris.com
jimglass
26
Reply #4 on:
October 07, 2013, 10:44:30 AM »
That worked, thanks Jeff
That file information got lost somehow in 2012. I made a hardcopy of that info and cannot find it.
Jim
Last Edit: October 07, 2013, 10:48:43 AM by jimglass
Print
Pages:
1
Go Up
« previous
next »
