Hello Guest it is November 22, 2026, 06:10:40 PM
Author Topic: SmoothStepper + C6 + Mitsubishi AC Servo MRJ2S  (Read 9093 times)
« on: October 07, 2013, 06:03:40 AM »
     Need some help on wiring C6 speed controller to SS.
Current wiring:
Used Pin 6 and 7 for step and Dir of SS port 1 wired them to C6 X2 Input Signal Connector, in X2 there's a EN CCW what do I do with it?
Applied 24V to C6's power input X1.
Relay 2 (x7) is energised, NO.
The Spindle RPM is 0, by pressing arrow up or down, still 0.
Analog output (X4) measures 0.02V no matter turning cw or ccw of the VR (X5).
Mach3 settings:
1 - Config--->Ports&Pin--->Motor output---> enable spindle step pin = 6, Dir pin = 7, step Port = 1, Dir port = 1.
2 - Config--->>Ports&Pin--->Spindle setup---->Motor control box check use spindle motor output and Step/Dir output.
Disable Spindle relays is unchecked setM3 output =2 setM4 output = 1
3 - Config--->Spindle pulleys--->Pulley Number 1 Min =0,Max =420, Ratio=1.
4- Config--->Motor Tuning--->Spindle--->step per = 1000, Velocity=2700, Acc.=450.
Please provide an wiring diagram for guidances,
thanks.
Re: SmoothStepper + C6 + Mitsubishi AC Servo MRJ2S
« Reply #1 on: October 07, 2013, 08:20:59 AM »
Got the spindle turning cw and ccw.
I'm not getting any voltage from X4 analog Terminal connector terminals, help..
« Reply #2 on: October 09, 2013, 10:41:51 AM »
problem solved.
