Hello
Guest
it is
October 21, 2026, 07:54:41 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Limit / Home Switches
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Limit / Home Switches (Read 23344 times)
booda88
7
Re: Limit / Home Switches
Reply #10 on:
October 06, 2013, 06:57:15 AM »
I don't think it is the ground . I think I found a programing error. I will check that later today. Thanks
Fastest1
920
Houston, TX
Reply #11 on:
October 06, 2013, 07:30:15 AM »
The shield is a drain for noise/stray signals. Connect at controller only (most of the time).
booda88
7
Reply #12 on:
October 06, 2013, 01:24:56 PM »
No I have a wire going to each of the connections on the micro switch and the shield is a different wire attached to the braiding.
booda88
7
Reply #13 on:
October 06, 2013, 01:30:46 PM »
No There is adifferent wire going to each of the connections on the micro switch. The shield is braided with a wire going to the board ground which I am going to change to case/earth ground.
Fastest1
920
Houston, TX
Reply #14 on:
October 06, 2013, 05:18:29 PM »
This is referred to as a star ground. Don't forget to bring your V- to this point also.
Print
Pages:
1
2
Go Up
« previous
next »
