Hello Guest it is October 21, 2026, 04:05:50 AM
Author Topic: Limit / Home Switches  (Read 23341 times)
Re: Limit / Home Switches
« Reply #10 on: October 06, 2013, 06:57:15 AM »
I don't think it is the ground . I think I found a programing error. I will check that later today. Thanks
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #11 on: October 06, 2013, 07:30:15 AM »
The shield is a drain for noise/stray signals. Connect at controller only (most of the time).
« Reply #12 on: October 06, 2013, 01:24:56 PM »
No  I have a wire going to each of the connections on the micro switch and the shield is a different wire attached to the braiding.
« Reply #13 on: October 06, 2013, 01:30:46 PM »
No There is adifferent wire going to each of the connections on the micro switch. The shield is braided with a wire going to the board ground which I am going to change to case/earth ground.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #14 on: October 06, 2013, 05:18:29 PM »
This is referred to as a star ground. Don't forget to bring your V- to this point also.
