Hello Guest it is November 24, 2026, 04:02:04 PM
Author Topic: How to edit/add keyboard shortcuts for "Button Scripts" ?  (Read 10779 times)
« on: September 29, 2013, 02:10:00 PM »
Dear Forum.
I'm running the Big-Tex Blue Screen set.
Where some customized appears: "Initial Zero Setup" and "Tool change zero"
I would like to add some keyboard shortcuts for those as minimum, but also for other function.
Is that possible ? and how do i get started ?
Further I'm looking at the PoKeys56U, the idea is to have a custom controlbox wired to PoKeys, and run some of the scripts.
Will I need above shortcuts be needed for that, or is there a "DoButton" command for the scripts ?
Best Regards, Bo Andersen.
Re: How to edit/add keyboard shortcuts for "Button Scripts" ?
« Reply #1 on: September 29, 2013, 02:17:42 PM »
You can set hotkeys for onscreen buttons in a screen designer, either Screen4 or Machscreen.
You may need to use a macropump to call scripts from external buttons.
« Reply #2 on: October 02, 2013, 12:23:27 PM »
Great, thanks.
I will look into Screen Designer Software.
« Reply #3 on: June 18, 2014, 11:59:02 AM »
shortcuts are already set up for those functions try CTRL+Z and ALT+Z
Thomas
Thank you for your support in developing better cnc experiance.
 Scan my avatar with smart pnone .......
http://big-tex.tk/
