Hello Guest it is November 13, 2026, 04:48:29 PM
Author Topic: OEM button code  (Read 21252 times)
OEM button code
« on: September 20, 2013, 10:18:09 PM »
how to number, the Command Reference all home number oem button
thank you.
udom.
Re: OEM button code
« Reply #1 on: September 20, 2013, 10:21:47 PM »
I will fix the code in the oem code or not.
Re: OEM button code
« Reply #2 on: September 21, 2013, 05:11:13 AM »
There is no Ref All OEM button. You'll need to use VB code in a button to Ref All. See how the default buttons do it.
Re: OEM button code
« Reply #3 on: January 30, 2021, 01:00:02 PM »
Hi all, Back in 2009 or 2010, don't remember which, I designed and built CNC mach3 controlled quilter for my wife who is big into quilting.  Here's the problem.  When I built the system, I used an HP Z5000 laptop computer that I inherited from my work as the control station.  We had much success up until I moved from Germany to the USA.  When we got back to the states after an absence of 10 years, I set up the quilter again, but had to use a different computer. I loaded up the Mach3 and set up the screens I had made to control the machine, but I found a problem.  My Rockcliff Parallel controller crapped out and I had to buy a new one.  My thought was to get a mach3 usb cnc controller.  Well, I got it and finally got the machine configured and running correctly.  Or so I thought!
What I found out was after installing Mach3, everything worked except one thing.  The "OFFLINE" toggle button! I've been pulling my hair out for almost a year now, and no joy!  I don't know if this is a programming issue, card related, or computer USB fault.  If anyone has any thoughts about how to resolve this issue I would be eternally greatful, and I am sure my wife would cook someone a nice dinner and a good bottle of California grape juice (Two Buck Chuck), and would most certainely resolve this constant headache I have.  Thanks for the consideration guys!
Larry Lamb
Re: OEM button code
« Reply #4 on: January 30, 2021, 01:37:03 PM »
The USB Controller you are using may not support the Offline function. Especially if it's Chinese.
