Hello Guest it is November 26, 2026, 06:39:11 PM
Author Topic: DRO external visualization  (Read 10782 times)
« on: September 18, 2013, 02:55:12 PM »
Hello, would display the angle of a blade of a cutter foam, this varies from -30 to 30 degrees. The PLC can send a PWM or variable frequency proportional to the angle. My problem is how i can use a DRO to see this angle.
I could use the RPM DRO but this is on another scale.
I can use a DRO with my settings, or how could see this angle?.
thanks
Renato
« Last Edit: September 18, 2013, 02:56:44 PM by Renatox_ »
Re: DRO external visualization
« Reply #1 on: September 18, 2013, 06:27:39 PM »
Without using an analog to digital converter board or a frequency counter board I don't think you can.
« Reply #2 on: September 18, 2013, 07:46:39 PM »
Hi, i use a ADC converter in my PLC to measure the angle of the blade, the PLC can send a signal to mach of PWM or variable frequency proportional to the angle of the blade.
For example, the PLC sends to mach a PWM of 50% for 0°, 100% for 30° and 0% for -30°.
My problem is how to visualize this angle.
thanks.
Renato
« Reply #3 on: September 18, 2013, 08:48:58 PM »
IF the ADC can talk modbus then you can bring the values to mach through the Modbus serial com. other than that you can't read the values .
« Reply #4 on: September 20, 2013, 02:11:02 PM »
Hello, can i modify the value of INDEX? This is for measurement rpm, then i would do
angle=(rpm-1500)*0.02;
Of this form i can obtain -30 a 30 DRO.
thanks
Renato
« Reply #5 on: September 20, 2013, 03:30:52 PM »
The index signal is a simple Digital signal it is either ON/OFF , 1/0. There is NO analog value to it to modify.
