Hello Guest it is October 24, 2026, 09:36:10 PM
Author Topic: please help having problem with mach3  (Read 9664 times)
« on: September 17, 2013, 10:16:00 AM »
hai .... i'm new user on mach3
I faced the problem where when I run the program on beginning at zero point and at the end of the program he will return to the zero point. but I found the tool I'm not at the zero point. but the x axis offset to the left of 1.5mm. y axis zero point. why x axis offset when Mach3 DRO shows COORDINATE X0.0 Y0.0 Z0.0?
but when I run a program that does not have a radius. at the end of the tool will return a zero point in the right circumstances.
« Last Edit: September 17, 2013, 10:19:18 AM by sa now »
Re: please help having problem with mach3
« Reply #1 on: September 17, 2013, 01:04:49 PM »
Sounds like you have the acceleration rate too high and the axis is loosing steps somewhere. Try lowering the accel rate by 1/2 and retest. If it fixes it then increase it until problems show up then back it down until they go away.
« Reply #2 on: September 17, 2013, 11:35:29 PM »
tq ... for reply...  if acceleration rate to high , isit possible only x axis offset ?...
Offline Fastest1
  •  920 920
  • Houston, TX
(No subject)
« Reply #3 on: September 22, 2013, 11:34:43 AM »
Each axis has its own acceleration and velocity settings. In most cases axis will respond differently even though they appear identically built.
