Hello Guest it is November 16, 2026, 06:54:43 PM
Author Topic: Re: video window camera- optical positioning/measuring -  (Read 48910 times)
Offline zarzul
  •  233 233
  • Wyoming, USA
« Reply #10 on: February 26, 2007, 12:26:42 PM »
Hood,
I am from the USA,  Wyoming.  It is one of the lowest populated states.
I can make these in a metric dimension if you need.  I may have to scrounge for metric setscrews.
Arnie
Re: Re: video window camera- optical positioning/measuring -
« Reply #11 on: February 26, 2007, 12:38:42 PM »
Thanks Brett, pretty impressive by the looks of it, not got a thou blade ;)
« Reply #12 on: February 26, 2007, 12:40:55 PM »
Arnie, sorry, what I was meaning was I asked the res in imperial but then you mentioned a mm scale so I just thought maybe you were from Europe.
« Reply #13 on: February 26, 2007, 12:49:40 PM »
Here is one with a .002 feeler guage with a little rust rust on it.
« Last Edit: February 26, 2007, 12:54:03 PM by Chaoticone »
« Reply #14 on: February 26, 2007, 01:00:17 PM »
:D
Just remembered I had a cam in a box of computer junk I got from a friend, hooked it up and put it over some digi calipers with the jaws open 0.05mm and although its hard to hold it steady I can see the res is pretty good.
« Reply #15 on: February 26, 2007, 01:06:00 PM »
You mean you can be that still at your age? I'm impressed.  ;D  I think you will like it Hood.
« Reply #16 on: February 26, 2007, 01:10:53 PM »
LOL
« Reply #17 on: February 26, 2007, 01:24:51 PM »
Heres a pic of the calipers set to 0.01mm (0.0005"approx), never realised the finish on these Mitutoyos was so rough ;)
« Last Edit: February 26, 2007, 02:52:30 PM by Hood »
« Reply #18 on: February 26, 2007, 01:54:31 PM »
LOL, Looks good Hood, I have found a new way to get splinters out of my hands.
« Reply #19 on: February 26, 2007, 10:34:34 PM »
Brett are you going to turn on the spindle and cut the chips out? hmmm Ron's CopyCat wizard would help you with the program for that ;)
www.newfangledsolutions.com
www.machsupport.com
