Hello Guest it is October 21, 2026, 12:13:53 PM
Author Topic: Limit switch triggered. Which axis???  (Read 10238 times)
« on: September 15, 2013, 08:15:59 PM »
About this message "limit switch triggered"
I have the limit switchs NC.
Debounce interval 500 (then increments 250)
My last setup Debounce interval is 2750. Is that enough?
Something I want to know is:
Specifically. Which axis is the trigger?
The message "Limit switch triggered",
NOT SAY to me, the switch triggered.
That I can do to know the trigger axis?
I appreciate any related information.
  •  9,374 9,374
Re: Limit switch triggered. Which axis???
« Reply #1 on: September 16, 2013, 01:12:28 AM »
Hi Riphet,
My view is that if it is not obvious which axis has triggered the limit switch then it could just be a false trigger. This can occur if the WatchDogs are enabled (Config / Gen Config) or if electrical noise is an issue - also mechanical vibration can activate some switches
Could you provide more details of when the limit switch triggered event occurs ?
« Reply #2 on: September 23, 2013, 02:45:21 PM »
That's the problem:
1. - Use watchdog is disabled.
2. - I do not know which switch triggered.
The machine works normal, but randomly trigger this message and stop.
Appears noise, but it was 4 months working without problems,
with Debounce interval ats 500.
Now Debounce interval is 3000. Is that enough?
« Reply #3 on: September 23, 2013, 03:02:21 PM »
First thing to ask is are you using the parallel port or an external controller?
