Hello Guest it is October 13, 2026, 11:50:30 PM
Author Topic: Mach3 variable list  (Read 41406 times)
Mach3 variable list
« on: September 07, 2013, 03:09:26 PM »
Please.  Can someone point me to a doc that lists the Mach3 internal variables, such as used in getvar(2002) to get the location of the z probe with contacting a touch plate.
I've looked everywhere I can think of and don't see a list or explanations of what they represent.  It would be a great help in understanding how the many scripts available on the forum work.
thanks in advance
Derrick
Re: Mach3 variable list
« Reply #1 on: September 07, 2013, 04:15:55 PM »
There are ONLY a handfull that are actually documented.
#2000 = Probe Tripped Value of X
#2001 = Probe Tripped Value of Y
#2002 = Probe Tripped Value of Z
#2003 = Probe Tripped Value of A
NOTE: These values are Probe Tip compensated IF you enter a value for Tip Radius. IF the value is left 0.000 then NO comp is applied to The Tripped Values.
« Reply #2 on: September 07, 2013, 07:12:58 PM »
There's also a few listed in the manual which specify the work offsets.
« Reply #3 on: September 07, 2013, 08:01:23 PM »
HIYA Ger, I have never been able to pull ANY of those Vars listed in teh Manual Up in Mach3. I don't think they were ever implimented.
Could be wrong but I just tried it again with
5161   ----> G28 X value
5181 -----> G30 X value
5222 -----> G54 X offset value
They always come up as ZERO (0) not matter what it was set to.
Note : EVEN if they worked what good would they be without conditional Gcode ???? That MIGHT be why they do not work, for me at least.
Just a thought, (;-) TP
« Reply #4 on: September 07, 2013, 09:59:07 PM »
The offset values work for me. I use them in my Auto Zero macro, to set the Z axis the same regardless of the current offset.
If CurrentOffset = 1 Then
ZOffset=GetVar(5223)
ElseIf CurrentOffset = 2 Then
ZOffset=GetVar(5243)
ElseIf CurrentOffset = 3 Then
ZOffset=GetVar(5263)
ElseIf CurrentOffset = 4 Then
ZOffset=GetVar(5283)
ElseIf CurrentOffset = 5 Then
ZOffset=GetVar(5303)
ElseIf CurrentOffset = 6 Then
ZOffset=GetVar(5323)
End If
For X = 5223 To 5323 Step 20
SetVar(X, ZOffset)
Next X
Sleep(250)
« Reply #5 on: September 07, 2013, 10:17:53 PM »
AH for the most part I have been looking at the wrong ranges of VARs (;-). You are correct.
If you ever need it I have a report generator that runs in Mach CB that gives the values of ALL the Vars up to 20,000.
Thanks for the Update, (;-) TP
« Reply #6 on: September 07, 2013, 10:34:54 PM »
I can't see where the G28 or G30 vars work. Do you know of any others that can be added to the list ?
There is a range of vars that are linked to OemDros and vise versa.
« Reply #7 on: September 08, 2013, 10:11:13 AM »
These have been confirmed
5211 - 5216  -------> G92 AND G52 offsets
15103 - 15108  ----->  X-C axis scale factor
Fixture offsets as per the Manual ------> OK
Still looking for more.
