Hello Guest it is November 12, 2026, 07:16:49 AM
Author Topic: M98 (subtest)file that's in subroutines folder  (Read 15284 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« on: February 22, 2007, 11:00:49 PM »
Hi, All
Can someone please post the Proper use of M98 (subtest)file that's in
subroutines folder, as described in Mach3 manual.
Haven't been able to import it into Mach3.
I'm Using Mach3 2.0.049
Thanks, Chip
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: M98 (subtest)file that's in subroutines folder
« Reply #1 on: February 23, 2007, 06:01:20 AM »
Hi Chip,
this bit works for me.
Graham.
G20 G40
G00 g90 g43 X-1. Y-1.
z1.
M98 (SUBTEST.TAP)
M30
Offline Chip
  •  2,055 2,055
« Reply #2 on: February 23, 2007, 12:19:12 PM »
Hi, Graham
This put me on the right track, your file loaded just fine.
But after working through the editing and save options to use other files, I found the Real Culprit.
I use WordPad text editor from time to time, it has 4 formats for saving files, RTF, TXT, MS- DOS and Unicode, text Document save options.
Mach will load all 4 of them, But the Unicode Txt will not show in G-code Window or View, My default editor for Mach is set to Notepad.
So when I hit Edit "notepad" in Mach, it shows the G-code txt just fine, Mach doesn't completely recognize the Unicode Txt though.
Try this File Below, let me now what you think.
Thanks for the Help, Chip
  •  2,785 2,785
« Reply #3 on: February 24, 2007, 03:12:06 AM »
Hi Chip,
I see your problem.
I don't use Notepad, I use Wordpad and I save with the following settings. It works for me every time.
Graham.
