Hello
Guest
it is
September 06, 2026, 01:06:46 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Will this work?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Will this work? (Read 12919 times)
Ray Jorgensen
4
Will this work?
on:
September 04, 2013, 10:27:06 AM »
About 15 yrs ago I built a small CNC it used a parallel port and I ran Mach.
8 yrs ago I bought a Thermwood 45 - 5' X 10' bed. Since then I haven't used my home made machine. I now want to re purpose it.
Can I run mach3 from my laptop with no parallel port? If so how?
ger21
6,295
Re: Will this work?
Reply #1 on:
September 04, 2013, 11:26:26 AM »
With an external motion device, like a Smoothstepper.
Ray Jorgensen
4
Re: Will this work?
Reply #2 on:
September 04, 2013, 02:04:50 PM »
My first question and I'm sure I know what the answer is going to be. NO A USB to parallel adaptor won't work?
Second - It looks like this replaces the old board that the drives are wired to. So I just need to connect existing steppers?
ger21
6,295
Re: Will this work?
Reply #3 on:
September 04, 2013, 02:18:33 PM »
No, the adapter won't work.
Actually, the breakout board that you had plugged into the parallel port should just plug directly into the smoothstepper.
Ray Jorgensen
4
Re: Will this work?
Reply #4 on:
September 04, 2013, 02:29:35 PM »
So the smoothstepper plugs to the computer via USB - The smooth stepper to existing board via parallel cable? Sorry if I'm slow in getting this.
ger21
6,295
Re: Will this work?
Reply #5 on:
September 04, 2013, 02:37:19 PM »
Correct. however, the Ethernet version of the Smoothstepper is preferred over the USB version. It's far more immune to noise issues.
Carnoustie, Scotland
Re: Will this work?
Reply #6 on:
September 04, 2013, 02:42:22 PM »
You will however need to make sure you get a parallel to IDC adapter so that you can plug direct.
Ray Jorgensen
4
Re: Will this work?
Reply #7 on:
September 04, 2013, 02:52:46 PM »
Thanks to all. This will make a very inexpensive solution.
I'm making a auto positioning stop for my chop saw. To buy one is 15K - I'll have less than $400 in it.
Print
Pages:
1
Go Up
« previous
next »
