Hello Guest it is November 11, 2026, 11:15:18 PM
Author Topic: change home routine (go to zero)  (Read 8821 times)
« on: August 30, 2013, 09:35:05 AM »
Using mach3
When I tell my mill to go to home
the x and y will move  first then z last
I want the quill to go up first so it will not crash or break a bit
how do I tell z to home first then x and y
I am new at this
thanks
harry
Re: change home routine (go to zero)
« Reply #1 on: August 30, 2013, 10:37:50 AM »
GoTo Zero is different than homing. The default Home routines home z first.
If you want GoTo Zero to go lift Z first, then enable Safe Z in Config > Safe Z.
« Reply #2 on: August 30, 2013, 10:51:01 AM »
thank you for the help
that is just what I wanted it to do
again thank you
harry
