Hello Guest it is November 03, 2026, 11:53:25 AM
Author Topic: Plasma Anti-dive function. Seems not to work  (Read 11086 times)
« on: August 29, 2013, 04:51:22 PM »
Hello,
Recently read a post about the Mach3 Anti-dive function. http://www.machsupport.com/forum/index.php/topic,16169.0.html
But it seems not to work just like BR549 said. Even programming it to 100% of the actual feedrate, the machine still move the Z axis up and down during the cut by the THC.
Someone with experiencie with this command?
Added it to my Plasma Screen, seems to be a nice feature to have if it works. Attached the screen for convenience.
Thank you,
Re: Plasma Anti-dive function. Seems not to work
« Reply #1 on: January 02, 2016, 02:46:57 PM »
« Last Edit: January 02, 2016, 02:48:56 PM by BR549 »
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: January 02, 2016, 03:26:26 PM »
It would do that - setting 100% is telling it you are ok at any speed.
Mine is set at 70% i think - if my code commands a feed rate of 4000mm/min but Mach3 computes it needs say 2000mm/min or 50% of my commanded rate for a corner it will stop the THC for that contour and resume it as soon as the machine accelerates to more than 70% again.
« Reply #3 on: January 02, 2016, 04:40:47 PM »
Hiya Dave My bad I accidently activated a very old post from 2013.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: January 03, 2016, 03:17:33 AM »
Oops ;)
Ah well, needed answering :)
