Hello Guest it is November 22, 2026, 07:42:54 AM
Author Topic: Relay Problem  (Read 8848 times)
Relay Problem
« on: August 29, 2013, 02:08:24 PM »
I'm running Mach Plasma the first relay I set up worked fine then all of a sudden the torch stopped firing.
I thought I had a bad relay so I replaced it. I changed nothing but relay. I can get it to fire in Mach Mill but not in Plasma.
C-10 BOB w/ relay wired to pin #9
Spindle set @ Output#1,
Output#1 is set to Active, Port 1, Pin 9, Active Low.
I have tried other pins but they will not work either. I've tried everything I could think of including reinstalling Mach 3.
Like I said it was firing great until it mysteriously stopped working. I'm baffled ???
Re: Relay Problem
« Reply #1 on: August 29, 2013, 03:03:19 PM »
Does the output LED light up on the diagnostics page?
Re: Relay Problem
« Reply #2 on: August 29, 2013, 03:12:58 PM »
yep
