Hello Guest it is November 18, 2026, 07:41:00 PM
Author Topic: Probing Wizard/Screen  (Read 11457 times)
« on: August 26, 2013, 08:25:36 PM »
OK Here what I have Probing functions for at this time. Anyone have something they want/need added?
  •  9,377 9,377
Re: Probing Wizard/Screen
« Reply #1 on: August 28, 2013, 05:55:50 AM »
Nice work Terry.
« Reply #2 on: August 28, 2013, 06:53:09 AM »
I created a screen tab a couple of years ago that does inside/outside of features & alignments, but found that depending on the mach3 version... issue arise. Finding the more I use Dynomotion the more I like it.
But good job Terry... You are keeping busy!
SOMEDAY! you are going to have to learn Lau?   :D
« Reply #3 on: August 28, 2013, 10:58:11 AM »
Lua too. ;)
« Reply #4 on: August 28, 2013, 11:32:44 AM »
What for to learn Lua ? Mach3 does not run Lua (;-)
Mach4 you say , WHAT mach4 ?
These routines RUN as Sub Routines. THey do not have the problems associated with Macros.
« Reply #5 on: August 28, 2013, 01:18:46 PM »
oops, fat fingers and getting OLD
« Reply #6 on: August 29, 2013, 09:35:18 PM »
This is Probing Functions Page2 JOG PROBING. It also allows you to create a SIMPLE Gcode file or a Simple DXF file from the points file.
