Hello Guest it is November 22, 2026, 10:33:29 AM
Author Topic: Feed rate  (Read 8750 times)
Feed rate
« on: August 20, 2013, 06:43:51 PM »
I am new to cnc and to Mach3.
I have a gcode for an image and the author told me to start the feed rate slow (6.00) and increase as needed.
My machine is set at 6.0 but when I start to run it goes to 150.00
How do I hold it at 6.0
Thanks for any help,
Pete
Re: Feed rate
« Reply #1 on: August 20, 2013, 07:46:42 PM »
The feedrate is normally call in the Gcode program. It overrides any setting made in mach3 prior to the program run. IF you cnnot change the Gcode then do a Feedrate Override lowering the feedrate to 6IPM .
Re: Feed rate
« Reply #2 on: August 20, 2013, 08:00:54 PM »
I realized that right after I posted. I changed the feed rate in notepad and it seems to be doing ok so far.
Thanks for the other info, I will need it most likely someday
Pete
