Hello Guest it is November 07, 2026, 02:53:44 PM
Author Topic: Sluggish Keyboard Response When Mach3 is running  (Read 13496 times)
« on: August 15, 2013, 07:08:05 AM »
I'm running the latest Mach3 under Vista with an ethernet smoothstepper. It mostly works well.
I find that when Mach3 is running the keyboard behaves oddly -- sometimes I get no response, and sometimes keystrokes seem to be batched up and then sent -- for example pressing tab to bring up the jog window sometimes doesn't work. I press tab a few more times, and then the jog window flashes on and off, as though multiple tab characters are being typed.
I have *not* installed the Vista memory override registry changes, believing that they are only needed if you are using a parallel port?
Thanks for any advice.
Tom
Re: Sluggish Keyboard Response When Mach3 is running
« Reply #1 on: August 23, 2013, 01:30:07 AM »
I've installed the registry path, and rebooted, but that hasn't improved things.
« Reply #2 on: August 23, 2013, 08:21:23 PM »
I've now installed Windows XP instead of Vista, and have reinstalled Mach3 -- same problem :-(
« Reply #3 on: September 06, 2013, 11:24:35 PM »
Taking the keyboard USB plug out and in again seems to fix the problem.
