Hello Guest it is November 18, 2026, 12:44:40 PM
Author Topic: issue where ESS would jog but not accept MDI commands.  (Read 10890 times)
« on: August 14, 2013, 09:23:51 AM »
Working on another machine.  The clients mache would jog, but when you used MDI to issue a command it would not move.  Then the machine would not jog.  You have to click reset, then reset again to go green and it would jog.  But still no MDI or Gcode run would make the machine move.
I notcied that in the selected devices that a plug in for the USB SS was in the plug ins directory.  Deleted it and all was well with the mill.
Again, just another FYI incase you run into this type of issue.
