Hello Guest it is November 22, 2026, 06:06:43 PM
Author Topic: Linking DRO to program, program uses whatever is put in the DRO..  (Read 8596 times)
Offline Tarak
  •  229 229
I've got this topic in another of my posts, but thought it may get a few more looks in it's own topic.
I've searched the forums and looked in Mach3 but I can't seem to work out how to get a DRO and a button that runs a program to interact.
I think I'm close, I want to have a DRO that you can put a measurement into and when you press a button it will use this measurement in the program, this is what I have.
Create a DRO, I assigned it to DIAMETER OF CURRENT TOOL (which I think is OEM code 105), should I select DIAMETER OF CURRENT TOOL from the drop down or should I enter the OEM code 105?
Create a button and assign VB code to it as follows:
Material = GetOEMDRO (105)
CODE "#1=Material"     ;In theory if 20 is entered into the DRO, Material should =20
CODE "G90 G55 G21
CODE "G00 Y[#1*2]    ;Rapid to Y40
CODE "G01 Y#1 F100  ;Linear travel to Y20
CODE "G00 Y[#1*2]    ;Rapid back to Y40
CODE "M30"
What am I doing wrong?
Offline Scott
  •  140 140
Re: Linking DRO to program, program uses whatever is put in the DRO..
« Reply #1 on: February 22, 2007, 11:50:13 AM »
Either 'DIAMETER OF CURRENT TOOL' or 105 should work, but I'd use 105 because I've come across a couple of the drop downs that didn't seem to work (I can't remember which ones) and the numbers have always worked.
Try this...
ToolDia=GetOEMDRO (105)
CODE "G90 G55 G21"
CODE "G00 Y" &ToolDia*2
CODE "G01 Y" &ToolDia & " F" &100
CODE "M30"
Pay attention to the "" marks and the &'s.  If you want to use #1 instead of ToolDia, then just declare it that way instead.
Scott
