Hello Guest it is November 22, 2026, 02:57:52 PM
Author Topic: Circles instead of Arcs ?  (Read 9966 times)
« on: August 09, 2013, 10:54:06 AM »
Hello Everyone,
I am using BobCAD v25 to generate gcode for my Mach3 controlled mill.  Most of my configuration is working well.
But when my gcode generates an arc, the result is a circle bigger than and well beyond the intended boundaries of the part.  The following line is an example of the gcode arcsbeing generated in my BobCAD post (nc) files:
     G03 X1.3285 Y.3853 I.0444 J-.0146
My gcode skills are not evolved enough to tell if this is a problem on the BobCAD or the Mach3 side of my process.
Can anyone point me in the right direction?
Bob
PS: I have tried to create this post a couple times now and keep getting errors.  My apologies to the group if this is generating duplicate topics.
Re: Circles instead of Arcs ?
« Reply #1 on: August 09, 2013, 10:56:26 AM »
Here is a copy of my Mach3 mill configuration file and a sample gcode file...
Bob
« Reply #2 on: August 09, 2013, 10:58:13 AM »
Try changing your IJ mode in General Config.
« Reply #3 on: August 09, 2013, 11:49:01 AM »
Thanks Gerry,
Changing the IJ setting from Absolute to Inc seems to have solved the problem.
Bob
