Hello Guest it is October 17, 2026, 04:28:19 PM
Author Topic: Mach4 Wizard screen shot  (Read 18275 times)
« on: August 08, 2013, 08:41:23 AM »
I wanted to show you an example of a wizard that I did in the new lua scripting engine. As you can tell you can have combo boxes.  buttons, Text boxes, images and so on.. This example will be open source and I am thinking about making a modual for LUA to help with making wizards so everyone will not need to know how to program LUA..
Enjoy!
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: Mach4 Wizard screen shot
« Reply #1 on: August 08, 2013, 09:14:05 AM »
I think it's worth stressing here that this was done 100% in the new scripting language Mach4 will be using. It is Lua and much more powerful than the Cypress enable in Mach3.
« Reply #2 on: August 08, 2013, 09:18:10 AM »
Yup.. 100% script! You can also imbed this script into the screen so you can add functions like this to your screen :)
 I can't wait to see what everyone will do with this over time.
www.machsupport.com
  •  9,374 9,374
« Reply #3 on: August 08, 2013, 09:57:52 AM »
Nice work Brian (and the team) I just can't wait.  ;D
« Reply #4 on: August 08, 2013, 10:01:45 AM »
I think I want it to be done more then anyone  >:D I am working on a tool changer macro now, as soon as I get that working I need to get the hot keys working for jogging and make some motor mounts for the plasma here. Anyone want to run a mill for me LOL
www.machsupport.com
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #5 on: August 08, 2013, 11:02:37 AM »
That looks really clean Brian. I like ...."I am thinking about making a modual for LUA to help with making wizards so everyone will not need to know how to program LUA.. " ;)
Thanks again Brian,
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
« Reply #6 on: August 08, 2013, 11:13:16 AM »
"Radio killed the video star"
  ;D :D
« Reply #7 on: August 08, 2013, 02:14:45 PM »
Interesting, How about sending down a version so I can try it AND a manual. If I can master it then almost anyone can if NOT?
Nasa we have a problem, (;-)TP
« Reply #8 on: June 20, 2014, 12:56:10 PM »
This looks great! Good job! I am just starting to try and learn Lua coding. I need a similar wizard that can do linear hole patterns rather than circles. Sounds like it shouldn't be too hard to modify this code to achieve a wizard for linear hole patterns but I really don't know where to start. Any Ideas that might help or have you seen a wizard that can already do this?
Rich
Offline 1Acnc
  •  28 28
« Reply #9 on: July 12, 2014, 11:54:54 AM »
1 Looks nice and clean. I like it.
2 I am one of your newbee user. What is a Drill cycle? Everything else was self explanatory. Maybe if I had the pull down feature to look at the list of option, it would be clear as to what it is. Or put a hint on the first item of the list.
