Hello
Guest
it is
November 22, 2026, 09:41:05 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
PhotoVCarve and Mach 3 ....will only carve 1/2" by 1/2".....help
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: PhotoVCarve and Mach 3 ....will only carve 1/2" by 1/2".....help (Read 22061 times)
96dodgeviper
16
on:
August 07, 2013, 06:40:55 PM »
No matter what I do, I can't get the CNC machine to carve larger then 1/2" by 1/2".
I even tried the samples that came with PhotoVCarve and also Mach 3.
I sent the file to the company that makes the PhotovCarve, and they said it is fine,
that it must be some settings in my Mach 3. Any information would be greatly
appreciated.
woodspinner
100
Re: PhotoVCarve and Mach 3 ....will only carve 1/2" by 1/2".....help
Reply #1 on:
August 07, 2013, 06:55:38 PM »
is photovcarve in inches and mach in mm?
Just a thought.
John
96dodgeviper
16
Reply #2 on:
August 08, 2013, 10:10:20 AM »
Both are in inches...good thought...I wish that were the problem. Thanks
woodspinner
100
Reply #3 on:
August 08, 2013, 10:52:16 AM »
I'll give it one more shot, if I remember correctly from my use of the trial version, first you load the image, second you define the material size, make sure the image size is set to something larger without a leading decimal point?
John
Last Edit: August 08, 2013, 10:53:48 AM by woodspinner
96dodgeviper
16
Reply #4 on:
August 20, 2013, 12:55:10 PM »
I double checked that I was using 15 x 12.9 inches.....and made sure the decimal point was not leading. Still carving about 1/2 inch by 1/2 inch.
Seems like I'm so close...but yet so far from finally figuring it out.
Thanks for trying.
Darrin
Picengraver
343
Reply #5 on:
August 20, 2013, 01:04:59 PM »
Are you sure that your Steps Per in Mach3 are set correctly? Sounds like they may not be.
John Champlain
www.picengrave.com
96dodgeviper
16
Reply #6 on:
August 20, 2013, 01:08:45 PM »
Sorry...new to all this. Where would I check to see if my "steps Per" are correct?
On a side note...I tried moving my "X" motor manually...to 18....and it only moved about 3/4 of an inch.
Picengraver
343
Reply #7 on:
August 20, 2013, 01:34:55 PM »
In the menu - Config > Motor Tuning. The formula to use to calculate the Steps Per is:
Steps per motor revolution X turns per inch of lead screw X microstep setting of the stepper motor drivers.
EX: 200 x 10 x 8 = 16,000 Steps Per.
John Champlain
www.picengrave.com
96dodgeviper
16
Reply #8 on:
August 20, 2013, 02:21:18 PM »
That is probably my problem. I went through the manual that came with the cnc machine...it tells me to choose between Inches and MM...I chose inches.
But when it comes to the "Steps Per" it only gives one set of numbers...which are probably in MM (came from China....which they tricked me..said it was "USA"..from CA).
So, I'm going to go onto the Company that makes Mach 3 and see if their manual gives me the settings I need to Tune the motor in Inches.
Thanks so much for your help...I would have never guessed that.
Darrin
woodspinner
100
Reply #9 on:
August 20, 2013, 03:16:59 PM »
You could try multiplying your existing numbers by 25.4 to account for the conversion, at least it may get you inthe ball park
John
Print
Pages:
1
2
Go Up
« previous
next »
