Hello Guest it is November 13, 2026, 08:08:08 PM
Author Topic: How would you trigger a recripricating air operated dot peen marking head?  (Read 8870 times)
So I have a CNC mill (Bridgeport) running mach 3, geckos, SS etc...
I just bought an TELESIS TMM4250 The marker does not have a controler. I would like to trigger the solenoids (piston extend) and (piston retract) using an output in Mach3.
I know how to have a solenoid operated with mach via an output, but I cant figure out a way to have the solenoids fire alternately and at a predetermined rate of fire.
How would you go about this? Write a script? ideas on what the script might look like?
Best,
Nate.
  •  9,377 9,377
Nate,
The digital trigger output pulses from the Impact / Laser plugin consist of two parts, an ON and an OFF with a maximum duty cycle of 50%.
Many have successfully used this plugin with electromagnets so I see no reason why it could not be used with an air operated solenoid.
This and other linked threads relate  http://www.machsupport.com/forum/index.php/topic,20490.0.html
Hope this helps.
