Hello Guest it is November 13, 2026, 07:55:20 PM
Author Topic: 2 flute grinding  (Read 25749 times)
2 flute grinding
« on: July 24, 2013, 06:41:34 AM »
Hi All
Thought I would try this!
http://s285.photobucket.com/user/GRAYHIL/media/flutegrinding.mp4.html?sort=3&o=0
Graham
Getting the flute angle is awkward.
« Last Edit: July 24, 2013, 06:45:16 AM by GRAYHIL »
Re: 2 flute grinding
« Reply #1 on: July 24, 2013, 09:35:57 AM »
That's fantastic Graham!  I dream about a machine like that. ;D
Can you post some details about the machine itself or have you posted something somewhere & I've missed it?
Milton from Tennessee ya'll.
« Reply #2 on: July 24, 2013, 11:41:32 AM »
Hi Dickybird
Its a 1950 ish colchester master lathe used as a 4 axis mill . X is the cross slide, Y is the vertical slide and Z is the top slide.
The 4th axis A is a rotary table which can be unplugged and a vice fitted instead.
The vertical slide and rotary table can be taken off and sustituted for the original toolpost and then I can use it as a Mach 3 lathe.
Graham
« Reply #3 on: July 27, 2013, 06:17:54 AM »
Not when you have a Darex end mill sharpener......guess I'm spoiled.  ;)
