Hello Guest it is September 29, 2026, 04:22:20 PM
Author Topic: Dro's do not match  (Read 19617 times)
Dro's do not match
« on: July 23, 2013, 10:14:56 PM »
Hello All, I'am new
    I got everything moving, made a simple cut GCODE on in mach turn with the wizard, Have my part placed in chuck, and part zeroed to placement ....and movement but no cut. However: I do see that the DRO's are way off. Just trying to do a simple cut..VERY SIMPLE. I'm running DEMO so that might be the problem, or the Steps per under motor turn....I have them set to 8000 did I do the math wrong?
Set-up
SHerline 4000 lathe 20 TPI
KL4030 microsteppers set at 1/8th 200
Any help would be much appreciated.
Re: Dro's do not match
« Reply #1 on: July 24, 2013, 01:49:01 AM »
Math = 20 x 200 x 8 = 32,000 Steps Per, not 8,000.
John Champlain
« Reply #2 on: July 24, 2013, 01:35:03 PM »
AWESOME THANK YOU! ;D. Now it's turning to the right instead of left ??? I don't see any reverse setting
« Reply #3 on: July 24, 2013, 01:49:01 PM »
Change the active state of the Dir pin setting in Ports and Pins, Motor Setup.
« Reply #4 on: July 24, 2013, 05:37:22 PM »
Sorry to bother....But it's still doing it.
« Reply #5 on: July 24, 2013, 08:37:20 PM »
It was just my Z direction. Thanks for all the help Hood
« Reply #6 on: July 25, 2013, 02:22:16 AM »
Did you get it sorted?
« Reply #7 on: July 25, 2013, 10:09:08 PM »
Yes sir I did. I love this software, 20 times easier than the other one I was using. Just waiting for next friday to purchase a licence.
« Reply #8 on: July 26, 2013, 01:54:58 AM »
Ok thats great, just wasnt sure if you were sorted or not :)
« Reply #9 on: July 28, 2013, 01:25:57 AM »
Might be a dumb question.....But can I still manually use my handles and have the DRO's follow my movement? My handles lock and I can't turn them when the power is on to my stepper motor's. Any suggestion?
