Hello Guest it is November 22, 2026, 02:27:42 PM
Author Topic: Import DXF into MACH3  (Read 19028 times)
maitresyoda
« on: February 20, 2007, 09:55:52 AM »
Hello, i would like to import a DXF file into MACH3. The file (see attach) is made with AUTOCAD2007 and TURBOCAD12. When Mach3 importe the file and i generate the GCODE, i can't see the text, only box or circle... I don't understand, can you help me ?? thanks
Re: Import DXF into MACH3
« Reply #1 on: February 20, 2007, 10:31:39 AM »
You need to explode the texzt using the Express Tools in 2007. And make sure you save the .dxf as version 12
maitresyoda
« Reply #2 on: February 20, 2007, 10:53:31 AM »
---You need to explode the texzt using the Express Tools in 2007----
Where is this option ? in autocad ?
maitresyoda
« Reply #3 on: February 20, 2007, 11:25:30 AM »
 its ok i install express tools in autocad and mach3 import correctly dxf file. thanks GER21
« Reply #4 on: July 29, 2007, 09:11:39 PM »
were do i find these express tools
