Hello Guest it is November 27, 2026, 09:43:02 AM
Author Topic: Simple Vacuum Hold Down  (Read 37220 times)
« on: July 09, 2013, 09:43:56 PM »
I've been asked many times how our vacuum hold down works, so I made a video to illustrate the construction.
I'm frequently getting asked about the use of our drag knife with Mach3, so I purchased the CNC Mogul machine to help learn more about Mach3.  This video shows the construction of the table for that machine.
EDIT: fixed picture link  ;)
« Last Edit: July 10, 2013, 04:41:17 PM by budman68 »
Re: Simple Vacuum Hold Down
« Reply #1 on: July 10, 2013, 04:08:02 AM »
The picture link does not work, please check and repost?
« Reply #2 on: July 10, 2013, 06:42:18 AM »
« Reply #3 on: July 10, 2013, 09:36:07 AM »
That's really too bad.  The link looks right, bit it goes nowhere.  Am I blind, or is there no way to edit a post?
http://youtu.be/fOrkvPF0pro
« Reply #4 on: July 10, 2013, 10:22:00 AM »
You didn't like my link?  ::)
You only have a few minutes to edit a post unless you can get a moderator or admin to edit it for you.
I liked watching your video, and fun to watch the kids keeping busy while you and mom glued at high speed.
There is always a trick to fix  ;)
Used your video name and replaced it with any youtube video, it pulled yours up, then I copied the http link from the webpage & pasted it here as a reply.
Edited: Just to show you it can be done, but quickly after posted!
« Last Edit: July 10, 2013, 10:28:37 AM by Ya-Nvr-No »
« Reply #5 on: July 10, 2013, 04:25:45 PM »
I liked your link.  Thank you.  My concern is people will click mine, find it doesn't work and move on, so I posted it two more times in hopes they scroll down and see it.  The problem with my link is the formatting on the html tags.  Looks like there are quotes in the link it pulls up.  They just need to be removed.
« Reply #6 on: July 10, 2013, 04:41:41 PM »
All fixed  :)
