Hello
Guest
it is
November 13, 2026, 12:52:25 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
mach to usb DAC from radio shack?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach to usb DAC from radio shack? (Read 12299 times)
turbothis
141
on:
July 09, 2013, 04:46:02 PM »
so the shack has these cute little boxes with nifty electronic crap in them. I want a different way to send the spindle speed command to my lathe from mach3 so I figure I would buy it and try out my luck. the BOB (c11g) DAC seems to be unreliable for threading and this was 20$.
anyone ever seen these?
http://www.vellemanusa.com/products/view/?id=500349
Uploaded with
ImageShack.com
in motor outputs the spindle would be set to some pin# on this and port 2 through the usb address?
spindle setup would be set to PWM and then it works? lol
Last Edit: July 09, 2013, 04:48:41 PM by turbothis
Logged
Carnoustie, Scotland
Re: mach to usb DAC from radio shack?
Reply #1 on:
July 09, 2013, 05:43:29 PM »
Almost certain the only way you will get that to work is write a plugin so that Mach can communicate with it.
Logged
turbothis
141
Reply #2 on:
July 09, 2013, 06:07:45 PM »
huh
well what about this thing from cnc4pc...
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=25&products_id=303
what do people use to get analog out of mach?
I love my Kflop/Kanalog but I don't have another 500 to pony up anytime soon.
Logged
Reply #3 on:
July 09, 2013, 06:12:37 PM »
Thought you already said the CNC4PC board was unreliable?
I have been using the CS-Lab controllers recently, they have analogue I/O on board for spindle and overrides etc.
Logged
turbothis
141
Reply #4 on:
July 09, 2013, 06:27:14 PM »
I have the big C11g BOB. the analog output on that has always been weird for some reason. instead of buying another spendy board I figure a new added on board for the spindle alone would be snappy.
when you say plugin are you saying some thing like a C code file?
Logged
Reply #5 on:
July 10, 2013, 01:58:15 AM »
Maybe the standalone board uses a different method of converting the signal to an analogue output than the integrated one, I have no idea. Personally however if I was unhappy with one of them I would be trying to get a resolution from the vendor and if that was not possible then I dont think I would be considering buying another from that same vendor in the offchance that it may be better. Of course that is just my thoughts, I have no experience with these products at all so cant say whether they are good or bad.
I have used a step/Dir to analogue board from Peter Homann and it worked very well and was very linear in operation but that is the only stand alone board I have used for spindle control.
As for plugins, C++ I believe it is, but it is beyond my skill-set so really I have no idea.
You will find some info regarding plugins here
http://www.machsupport.com/software/downloads-updates/
and
http://www.machsupport.com/forum/index.php/board,28.0.html
Logged
Print
Pages:
1
Go Up
« previous
next »
