Hello Guest it is September 20, 2026, 12:16:11 AM
Author Topic: <--Newb! Scorpion tutorial - scale changes when loaded (m2)  (Read 9356 times)
Offline PatM
  •  19 19
« on: February 19, 2007, 08:03:36 PM »
I' just setting up my first CNC machine, so I'm fairly close to completely lost ;)
Anyway, I got everything set up and running perfectly (as far as I can tell) without GCode loaded. All the axis travel in the proper directions and exactly the right distances. I set a dial micrometer up and tested by jogging around and making sure the DRO and the dial micrometer agree. The soft limits work perfectly etc.
Then, I loaded the scorpion demo as per the instructions and suddenly the DROs report FAR more movement than is really happening. I move about 1" and the soft limits kick in, as if I'd move over 25". If I manually jog, the same thing happens.
I've been perusing the Mach 2 manual and I just can't seem to find anything that tells me what to do about this. There is a paragraph on scaling, but it doesn't really say anything useful.
Any hints?
P.S. This is a licenced version. I have Mach 3 as well, but I can't seem to get that to move the machine at all. I figure I'll use mach 2 until I understand a fair bit of it, then see what I can do to get mach 3 working.
Re: <--Newb! Scorpion tutorial - scale changes when loaded (m2)
« Reply #1 on: February 19, 2007, 08:36:50 PM »
Hey Pat, I have sent you a personal message.
Offline PatM
  •  19 19
« Reply #2 on: February 19, 2007, 10:16:25 PM »
Well, I switched to the roadrunner example and that worked perfectly. Dunno whats up with the scorpion and its too late to be making all that noise out in the shed so I won't be able to play again until tomorrow. Good news is, I have the next two days off!
I also thing I figured out why Mach3 wouldn't move the machine. The XML setup file looks buggered - so I did a copy and paste from the vendor instead of "save target as" like they say to do. Now it looks proper. We'll see tomorrow!
