Hello Guest it is November 22, 2026, 06:15:07 PM
Author Topic: VB script consuming too much resources  (Read 14194 times)
« on: February 19, 2007, 04:24:49 PM »
Ok, I have a VB script running in the macro pump, and it uses 99% of my computers resources, so sometimes it slows down, It may be my way of coding or something. Anyone here sees something wrong with the code?
BB=0
CC=0
DD=0
EE=0
FF=0
Do While GetUserLed(1020)=1
Code "G01 A36"
While IsMoving()
Sleep 100
Wend
If IsActive(Input1)=TRUE Then
BB=1
Else
BB=0
End If
If BB=0 And DD=0 And FF=0 Then
DeActivateSignal(OUTPUT1)
DeActivateSignal(OUTPUT2)
DeActivateSignal(OUTPUT3)
ElseIf BB=1 And DD=0 And FF=0 Then
ElseIf BB=0 And DD=1 And FF=0 Then
ElseIf BB=0 And DD=0 And FF=1 Then
ElseIf BB=1 And DD=1 And FF=1 Then
ElseIf BB=1 And DD=0 And FF=1 Then
ElseIf BB=1 And DD=1 And FF=0 Then
ElseIf BB=0 And DD=1 And FF=1 Then
End If
CODE "G04 P375"
While IsMoving()
Sleep 100
WEnd
CODE "G04 P375"
While IsMoving()
Sleep 100
WEnd
FF=EE
EE=DD
DD=CC
CC=BB
Loop
End
Re: VB script consuming too much resources
« Reply #1 on: February 19, 2007, 04:37:50 PM »
Hey Fer,
   I remember seeing something about this a while back. I can't remember for the life of me what it was for sure. I think it may have been the While if statements.
« Reply #2 on: February 19, 2007, 05:38:07 PM »
Do you have this line at the start of your code?
Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long)
« Reply #3 on: February 19, 2007, 05:49:07 PM »
no, let me add it, and let you know
Fernando
« Reply #4 on: February 19, 2007, 06:02:59 PM »
Is there a VB command, that acts as a dwell? i dont know, like:
DWELL 100
or
PAUSE 100
where the 100 is in milliseconds?
Regards
Fernando
« Reply #5 on: February 19, 2007, 06:15:40 PM »
Thanks a lot Ger,
That did it, CPU load less than 1%
Still, Is there a DWELL or PAUSE command?
Regards
Fernando
« Reply #6 on: February 19, 2007, 07:30:16 PM »
the code"G4" doesn't work for you? I don't know of a "pause", but I'm not a programmer either. :)
« Reply #7 on: February 19, 2007, 07:32:39 PM »
It delays, but its not as precise As I would like it to be... I could try lowering the argument on the sleep command to make it better
Fernando
