Hello Guest it is November 13, 2026, 05:08:01 PM
Author Topic: PoKeysU and optocoupler encoder  (Read 16504 times)
« on: July 02, 2013, 06:37:32 PM »
I would like to connect "encoder" to PoKeys but enclosed manual is very limited. I tried to find something more detailed about that, but without any special success.
I shortly explain what I need.
I have no special encoder but I would like to use 2 optocouplers sending quadrature signals using encoder weel. I’m not sure if PoKeysU can use that signals from mentioned 2 optocouplers directly, or do I need additional electronics which convert signals from optocouplers into 2 independent signals for both directions independently (something like encoder quadrature decoder)?
Thanks for every help.
Offline NeoTO
  •  504 504
    • PoLabs
Re: PoKeysU and optocoupler encoder
« Reply #1 on: July 03, 2013, 11:10:18 PM »
Hi, Maciej
As we answered you to your email question, PoKeys already has multiple quadrature decoders built-in. You only have to connect encoder A and B (logical) signals. Make sure that you provide a proper signal to PoKeys device - clear signal transitions between 0 and 3.3 (or 5) V.
Matevž
