Hello Guest it is November 22, 2026, 03:03:57 PM
Author Topic: G41 and profiling gives rounded corners with "Exact stop" ?  (Read 18929 times)
Hi All.
Rather newbie to Mach3, and G-code.
Hand coded below:
Idea is to profile a 50x50 square, using climb mill, and G41 tool offset.
While doing so the toolpath is correct but rounds the corner with same Radius as the cutter.
Have tried:
Change settings to "Exact stop"
Add G61 to the init code
all gives rounded corners ?
If i change tool cutter radius to 0, I get sharp corners.
Code: [Select]
M06 T01 (Tool change #1)
G41 P5 (Left tool compensation, Radius = 5)
M03 s27000 M08 (SPINDLE AND FLOOD ON)
G00 x-5.0 y0.0 z0.0
G01 X0.0 F500.0
Z-1.0
Y50.0
x50.0
Y0.0
X0.0
G00 Z50.0
G40
M00
Where did I go wrong ?
Best Regards, Bo Andersen.
Re: G41 and profiling gives rounded corners with "Exact stop" ?
« Reply #1 on: July 02, 2013, 02:31:17 PM »
That's how comp works. It "rolls" around the corner with a radius toolpath, but your part will still have a square corner.
« Reply #2 on: July 02, 2013, 02:46:31 PM »
*Face-palm*
Of course it does. Only checked the tool path, in MACH 3 and I was tricked to perceive it as a rounded corner.
Thanks for a quick response.
« Reply #3 on: July 02, 2013, 07:11:53 PM »
*Face-palm*
I'm picturing the kid in the cell phone commercial explaining what  happens to a slow turtle in the road. ;)
« Reply #4 on: July 03, 2013, 06:41:18 AM »
 :D :D :D
Thanks ,
 ;D
"It's not complicated ..... faster is better."
« Reply #5 on: July 03, 2013, 04:22:39 PM »
women would disagree with that.
you guys watch too much TV, now get back to work.
« Reply #6 on: July 05, 2013, 03:47:25 AM »
Apparently you haven't been with many women as they're not robots and they surely don't act all the same  ;)
« Reply #7 on: July 05, 2013, 04:30:44 AM »
would that be the Budweiser and last call women?
« Reply #8 on: July 05, 2013, 04:43:48 AM »
So you have been there  :D
  •  9,378 9,378
« Reply #9 on: July 05, 2013, 07:39:40 AM »
 ;D ;D ;D
