Hello Guest it is November 03, 2026, 09:42:07 AM
Author Topic: Error message from Mach3 on G02 interpolation movement  (Read 9637 times)
ridesideways
« on: February 19, 2007, 03:04:35 PM »
I'm having trouble with Mach3 (version 2.0) during the loading of the G code file and Mach3 does a simulated run to test the progrom.  Basically it complains with the following status message: "Radius to end of arc differs from radius to start on line number 1940".  Does this message from Mach3 seem legitimate based on the G code snippet below?  Or is possibly the problem with my CAM software (RhinoCam with post for Mach 2) generating invalid G code?
Here is the snippet that Mach3 is complaining about:
N1920 G01 X0.9810 Y1.5748
N1930 G01 Y2.6077
N1940 G02 X-0.9817 Y2.6085 I0.0000 J3.5151
N1950 G01 X-0.9829 Y1.5239
I'm very stuck right now-- I've never had this problem before with RhinoCam and Mach3. Thanks in advance for any advice you can provide me.
-Eric
Re: Error message from Mach3 on G02 interpolation movement
« Reply #1 on: February 19, 2007, 03:08:19 PM »
try changing the IJ Mode on the General Config page in Mach.
