Hello Guest it is November 13, 2026, 07:01:43 PM
Author Topic: probe inside  (Read 11744 times)
Offline Jim P
  •  23 23
probe inside
« on: June 27, 2013, 11:49:22 AM »
I have been looking for a macro to probe the inside of an object in x and y only. i know there is one user that is working on something like that but the last post I found he was off to work out the bugs. Can someone point me in the right direction. it would be used to......... say you have a box with an irregular shape and you wanted to cut a lid for it with a piece that actually slid into the box. I might not have phrased my search right but after looking for a couple of days I can not find anything. I looked in the tool box anddid may searches with multiple key words.
Jim
Re: probe inside
« Reply #1 on: June 27, 2013, 12:23:18 PM »
Look in the Mach Tool Box section and use the Interior Probing array. IT will do what you need.
Offline Jim P
  •  23 23
Re: probe inside
« Reply #2 on: June 27, 2013, 02:03:22 PM »
I looked at that, I thought it was doing something else. I'll try it out. thanks for the suggestion.
Offline Jim P
  •  23 23
Re: probe inside
« Reply #3 on: June 27, 2013, 02:22:46 PM »
I just did a search with every concievable combination of Interior probing array and could not find it. The only thing i found was the find center of a circle on the x axis. its not a circle. I'll keep searching.
Re: probe inside
« Reply #4 on: June 27, 2013, 03:36:16 PM »
Sorry I guess I never copied them over to the MachTool Box. They are in a zip file which contains the arrays (int and Ext) and the support MACRO and the user's manual.
They are there NOW (;-)
http://www.machsupport.com/forum/index.php/topic,24916.0.html
(;-)TP
Offline Jim P
  •  23 23
Re: probe inside
« Reply #5 on: June 28, 2013, 08:51:31 AM »
thanks a ton. i downloaded the files last night.
Jim
