Hello
Guest
it is
October 21, 2026, 02:25:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
General CNC Chat
Show"N"Tell ( What you have made with your CNC machine.)
Machining the compass inserts
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Machining the compass inserts (Read 44017 times)
Chaoticone
5,624
Precision Chaos
Re: Machining the compass inserts
Reply #10 on:
February 20, 2007, 07:34:54 AM »
Dan, Dan the high tech man.
I don't see why it wouldn't. All you need is a way to hold the pencil end rigid, and repeatable, and rout the flex shaft to turn it. I bet you work for NASA.
If you could see the things I have in my head, you would be laughing too.
dfurlano
252
Reply #11 on:
February 20, 2007, 12:38:31 PM »
Not bad but a little pricey.
http://www.macrotechnologies.com/high_speed_air_spindle_mini_mac.htm
marcel beaudry
153
Reply #12 on:
February 20, 2007, 06:37:44 PM »
look at cnccookbook.com and see what he does with is dremel
Marcel
dfurlano
252
Reply #13 on:
July 12, 2007, 11:39:00 AM »
There is a lot of room between $5000 and ripping B&D off.
Last Edit: July 12, 2007, 11:40:41 AM by dfurlano
DavidCousins
60
Reply #14 on:
July 23, 2007, 04:15:33 PM »
Try using a $119 router with a 1/8 inch collet adapter. It will last forever, and you won't be putting yourself in a position that can be viewed as dishonest.
Print
Pages:
1
2
Go Up
« previous
next »
