Hello Guest it is October 21, 2026, 12:03:28 AM
Author Topic: Machining the compass inserts  (Read 44011 times)
Re: Machining the compass inserts
« Reply #10 on: February 20, 2007, 07:34:54 AM »
Dan, Dan the high tech man. ;D   I don't see why it wouldn't. All you need is a way to hold the pencil end rigid, and repeatable, and rout the flex shaft to turn it. I bet you work for NASA.  ;D
« Reply #11 on: February 20, 2007, 12:38:31 PM »
« Reply #12 on: February 20, 2007, 06:37:44 PM »
look at cnccookbook.com and see what he does with is dremel
Marcel
« Reply #13 on: July 12, 2007, 11:39:00 AM »
There is a lot of room between $5000 and ripping B&D off.
« Last Edit: July 12, 2007, 11:40:41 AM by dfurlano »
« Reply #14 on: July 23, 2007, 04:15:33 PM »
Try using a $119 router with a 1/8 inch collet adapter.  It will last forever, and you won't be putting yourself in a position that can be viewed as dishonest.
