Hello Guest it is September 23, 2026, 02:56:00 PM
Author Topic: so I need 'at most' an windows 7 computer running 32 bit ?  (Read 12102 times)
Offline nobby
  •  154 154
« on: June 15, 2013, 02:33:35 PM »
can use one of those little dell things, with the small boxes that have a serial port.
Offline olf20
  •  325 325
Re: so I need 'at most' an windows 7 computer running 32 bit ?
« Reply #1 on: June 15, 2013, 05:10:32 PM »
No - parallel only unless you use a external motion control like
smooth stepper.
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Offline nobby
  •  154 154
« Reply #2 on: June 15, 2013, 05:14:59 PM »
thats what I meant parallel
i think
Offline P_D_B
  •  35 35
« Reply #3 on: June 15, 2013, 07:22:25 PM »
You have to watch the serial ports now on laptops and some desktops as the serial port is emulated now and not a traditional port and most all laptops are emulated serial ports.  The trend is moving toward smooth steppers as parallel ports are not always supplied on all motherboards anymore.   I would stick with 32 bit of XP, Vista or 7 as they have been used but it seems XP is the flavor.
Remember Einstein said this...."We can't solve problems by using the same kind of thinking we used when we created them."
__________________________________
Pete
Offline P_D_B
  •  35 35
« Reply #5 on: June 18, 2013, 09:50:21 PM »
All I can say is I tried 2 computers until I had one that worked with Mach3 and both computers are the exact make and model of Dell.  Others here have never had a problem.  Sorry I can not be more help but if you have a computer to test it with go for it but to purchase one I would say it is a 80 20 shot with lean more toward the 80.
Pete
