Hello Guest it is October 21, 2026, 12:03:34 AM
Author Topic: water cooled head for motorised pushbike  (Read 24689 times)
« on: June 15, 2013, 07:07:54 AM »
im baaaack!
i been making a mess again  :-\
what did i do?
well, i got to playing with making heads on the lil x2 baby!
first, turning a hemisphere. this pic isnt actually the head this threads about! and neither is the hemi turner! thats later...
neither is the second. but a good demonstration of software. i have deskproto and meshcam. to cut a profile like this, meshcam wins, hands down. despite some of the odd moves. theres not enough fins, i should have used a 6mm cutter and stuck with my original parallel fin plan. i got lots of performance just before getting lots of auto detonation :)
third is the head, undergoing water passage creation. i felt like a rainbow serpent or summink :) once again, meshcam. bit of chopping with the code and i got it done in 10 mins :) i need coolant on this beasty still...
fourth, all fitted up with a plug after a good run. performance? awesome :)
no more pics? hmmmph.
thats about it. i tried making a pump with neo magnets to drive off the magneto. failure. nice machining. i took no pics anyways :)
oh well.... now onto the topic i came here about...
Re: water cooled head for motorised pushbike
« Reply #1 on: June 15, 2013, 09:05:12 AM »
A b6e is way too hot of a plug for high compression you should be at B8e-B9e range.
« Reply #2 on: June 15, 2013, 10:07:51 AM »
its the only plug i had lying around! the rest are all H threads. seems to be running fine, if maybe too COLD. ceramics dark and if i go any leaner it wont start.
