Hello Guest it is November 13, 2026, 09:38:38 AM
Author Topic: Rectangular Pockets have curved ends  (Read 9864 times)
Offline PaulWC
  •  125 125
« on: June 14, 2013, 01:05:34 AM »
While trying to troubleshoot a gaining/losing step problem, I developed a test block code, hoping to help identify the problem... to be subject of another thread.
The current issue is the actual run produces odd curved ends on what should be rectangular ended slots. I thought it was a result of Constant Velocity, so changed to Exact Stops, and the problem got worse.
The cutter is a 4FL 1/4" carbide ball mill held in an ER11 on-size fractional collet, running at 19000 rpm, 175 ipm, 0.3125" depth per pass,in soft fir... so deflection shouldn't be a factor.
The attached pics show the run result, TurboCAD/CAM path and simulation, and CutViewer simulation. I also checked the code, and it defines rectangular paths.
Dial indicator check shows no backlash. Mach3 ver .066.
Any suggestions?
Offline PaulWC
  •  125 125
Re: Rectangular Pockets have curved ends
« Reply #1 on: June 14, 2013, 01:09:08 AM »
And here's the xml...
« Reply #2 on: June 14, 2013, 05:33:53 PM »
I have had the same problem with my CRP-4948. Ahren over at CNC Router parts suggested it was the CV settings. I haven't had a chance to investigate further. One thing I noticed was if I drop the feed rate down that the problem went away. You might try that.
-Freeman
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
I'm not a complete idiot...
    there are some parts missing.
Offline PaulWC
  •  125 125
« Reply #3 on: June 14, 2013, 07:31:10 PM »
Just checked my code, and TurboCAD/CAM had inserted a G64 line. I've changed it to G61, and will see what happens next run.
Thanks, Paul
