Hello Guest it is October 20, 2026, 06:45:26 PM
Author Topic: Poem  (Read 14348 times)
Poem
« on: June 14, 2013, 12:54:15 AM »
Hi there, has any one done any text engraving in wood, more then just a sign, such as a poem or a couple of paragraphs on mdf? If yes I would like to hear from you, I have a poem of about five paragraphs long it needs to be cut into mdf of a certain size to fit into a frame, what is the best program or text writer to use?
Re: Poem
« Reply #1 on: June 14, 2013, 01:54:12 AM »
I would imagine Vectric would but I'm sure there are others as well.
This may help
http://www.machsupport.com/forum/index.php/topic,24806.0.html
Re: Poem
« Reply #2 on: June 14, 2013, 03:36:19 AM »
Ok, who else clicked on this expecting...  a poem!
I have never seen a thing
as lovely as can be
It is not a swaying tree
It is, Mach3
(ok there, now you've seen what you came for - move along!  :D )
Re: Poem
« Reply #3 on: June 14, 2013, 04:10:25 AM »
 ;D
Re: Poem
« Reply #4 on: June 14, 2013, 07:18:54 AM »
as lovely as can be
It is, Mach3
op
That's great, now if you can convert it into G code I would be  as happy as one can be !
Re: Poem
« Reply #5 on: June 14, 2013, 07:24:20 AM »
I would be even happier if you tried using the suggested program and then came back if you had a problem. ;)
« Last Edit: June 14, 2013, 07:26:16 AM by RICH »
Re: Poem
« Reply #6 on: June 15, 2013, 03:03:28 AM »
Easy and all done by Mach in the write wizard ;)
Re: Poem
« Reply #7 on: June 15, 2013, 05:58:41 AM »
Thanks every one, I will have a go using the write wizard,I don't have access to Vectric, if I can get it right, I may even post the poem, cheers every one!
Offline Vogavt
  •  260 260
Re: Poem
« Reply #8 on: June 26, 2013, 08:17:24 PM »
 The best free open source software I've ever found is here
