Hello Guest it is November 07, 2026, 04:19:55 PM
Author Topic: Parallel port missing  (Read 27959 times)
« on: June 13, 2013, 08:54:58 AM »
I had to migrate to a new PC recently, and I have been stumped by the parallel card. I have a windows 7, 32 bit computer with a parallel port attached to the PCI-E bus. And for the life if me I cant get the Mach3 to interact with the parallel port.
A poster on the buildyourCNC forum suggested that MACH3 cannot see the parallel port on a PCI-E bus. Is that true ?
Re: Parallel port missing
« Reply #1 on: June 13, 2013, 11:39:32 AM »
I have never used a PCI-E card but know others that have with good results.  Are you loading and running everything as Administrator?
« Reply #2 on: June 15, 2013, 04:22:19 AM »
Make sure that it is a true P-port and not a usb implementation of one.
Mike
« Reply #3 on: October 10, 2013, 02:36:37 PM »
My old PC is getting past it, I am thinking of running my CNC with a lap top any ideas of what spec I should go for and is there any problems that I might have to watch out for
Ray
« Reply #4 on: August 27, 2014, 07:21:58 PM »
I just started this.  I struggled to get the thing (Mach3) to even boot up.
Just can't get it to make the mill budge.  Nothing.  Nada.  Not even a twitch, trmmer or shimmy.  Nothing.
Am at a loss.
I know there has to be a reason for it but right now I have no flippin clue.
3 days now and not a single thing is moving.
Going to have to dig up some documentation and see if there is something I have to do like sacrifice a chicken at midnight while dancing under the full moon.
It's going to be a VERy rough week.
Hey if this turns into a flop Ill have a PC, Mill and software for sale!
So disappointing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BTW I am running a win 7 64 bit, start with run as admin. All requirements met or exceeded, no alerts or request for action to trouble shoot.
The parallel is a pci card.
« Last Edit: August 27, 2014, 07:28:06 PM by DingusMcgee »
« Reply #5 on: August 27, 2014, 08:50:22 PM »
You can't use a parallel port on a 64 bit OS. Mach3's parallel port driver won't run.
A 32bit OS is one of the requirements to use the parallel port.
« Reply #6 on: August 27, 2014, 09:07:15 PM »
So what do I need to do?  I went with this assumption that I could.  This is off their website.  What do I need to do to run my mill with Mach3 off this computer?
Laptop, 32 or 64-bit Desktop – External Motion Controller Only
    An appropriate external motion controller (options can be found on the Plugins page)
    Windows 2000, Windows XP, Windows Vista, Windows 7, or Windows 8
    1Ghz CPU
    512MB RAM
    Video Card with 32MB RAM(Large G-code files, especially 3D files will require a video card with 512MB RAM or higher)
« Reply #7 on: August 28, 2014, 07:04:03 AM »
For 64 bit PC's, you need to use an external motion controller. The most popular is the Smoothstepper, from www.warp9td.com
« Reply #8 on: August 28, 2014, 09:16:29 AM »
Why did I not see that coming.
Ok, thanks for the info and the link.
I should have known that the deal on the cnc mill was going to end up being expensive....... >:(
« Reply #9 on: August 28, 2014, 09:46:11 AM »
There are other options. Look at the UC-100, it's a little cheaper. http://www.cnc4pc.com/Store/osc/product_info.php?cPath=93&products_id=481
