Hello Guest it is September 23, 2026, 02:45:34 AM
Author Topic: Many many inputs  (Read 10363 times)
Many many inputs
« on: June 13, 2013, 06:41:56 AM »
Hey all,
Im well on the way to building my SX3 CNC mach based machine.  As this is my only milling machine I wanted to be able to use it as a manual machine too, so after looking on ebay I got three chinese mpg wheels and have made some mounting brackets.
I am also making my control unit in a computer box to keep everything tidy.  I plan to fit a 4th axis driver soon too.
But, this requires two inputs per axis plus some other switches to control x10 x100 etc so my question (whilst showing progress) is: are there any opto-isolated breakout boards which favour inputs over outputs i.e. I want as many inputs as possible, that work with a smooth stepper and mach3 and are cheap......
When I get some more time I will post the progress leading upto this point.
Rob.
Re: Many many inputs
« Reply #1 on: June 13, 2013, 07:10:55 AM »
I like pmdx 122's.  Have a look at their docs on PMDXs site. You can set pins 2-9 as inputs.  There small and with the right stand offs you could stack them up. I ran my MPG straight to the SS though, port 3.  This gives me no optical isolation on those inputs though.  I can't remember all the details of why but the inputs I used for the MPG had to be normal inputs, not outputs selected as inputs (2-9).
Offline Fastest1
  •  920 920
  • Houston, TX
Many many inputs
« Reply #2 on: June 13, 2013, 11:07:01 AM »
The PMDX 126 is a great unit too. It allows the SS to plug in directly. It has expanded mode capabilities that allow more inputs on a single port if desired. It has plenty more abilities I don't even begin to understand ;-)
