Hello Guest it is November 18, 2026, 06:10:36 PM
Author Topic: Macro to rehome Z?  (Read 8179 times)
Macro to rehome Z?
« on: June 06, 2013, 01:59:21 PM »
I've been building an automatic toolchanger for my mill.  Mechanically, it's now finished, I just need to add some sensors (waiting for UPS) and program it under Mach.  One issue is that my Z-axis shifts slightly as the power drawbar fires.  Since the toolchange happens right next to the home switch for the Z-axis, my plan is to rehome Z as the final step in the toolchange macro.  Can anyone tell me the actual lines of code needed to do this?
Here's info about conversion, there is a video of the ATC operating under manual-control part way down the page.
http://coreyrenner.tumblr.com/
Thanks for the help.
cheers,
c
Re: Macro to rehome Z?
« Reply #1 on: June 06, 2013, 03:57:46 PM »
I believe it's just DoButton(24)
« Reply #2 on: June 06, 2013, 04:05:25 PM »
Aha!  Thanks ger21.
I found more info on syntax here:
http://www.machsupport.com/forum/index.php?topic=19565.0
cheers,
c
