Hello Guest it is November 13, 2026, 09:42:32 AM
Author Topic: Doesnt work each axies!!!!  (Read 8674 times)
« on: June 06, 2013, 04:24:57 AM »
Hy alls,
    In this period im preparing for my graduate exam. My proiect is a CNC turn machine and i want to use mach 3. I istallated but apeared a problem. When i tried manual mode just X axie is working, others doesnt work. The software shows me that its send semnals but the machine do noting. What would be the problem?????? (I tested my driver in Kcam and its working well.)
  •  9,377 9,377
Re: Doesnt work each axies!!!!
« Reply #1 on: June 06, 2013, 05:32:34 AM »
It could be a configuration issue in which case the Mach3 manual will be of help to you.  http://www.machsupport.com/documentation.php
It could be an electrical issue (incorrect wiring) or fault in your axes driver (damaged component) re-check everything thoroughly.
If you are using the computer's Parallel Port then it may be worth checking (pin for pin) your LPT cable as some cables have caused others problems in the past.
« Reply #2 on: June 06, 2013, 08:46:11 AM »
Finaly i found the problem. It was the pin numbers. for each motor i associated the common pin numbers but for me needed different, for ex. axie X 2 and 3 for me needed 3 and 2 that was.
    Anyway, Thank you for the fast reaction,
 All the best!
