Hello Guest it is November 17, 2026, 09:01:42 AM
Author Topic: Ethernet Smoother Stepper can't get motor movement  (Read 56675 times)
Offline Alax7
  •  15 15
Re: Ethernet Smoother Stepper can't get motor movement
« Reply #10 on: June 06, 2013, 02:51:39 PM »
Where would you find that?
Like I said, I'm new to this
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #11 on: June 06, 2013, 03:16:26 PM »
When you start up Mach3 look in the lower right corner of the screen. The name of the profile you are using will be printed there. Now shut down Mach3 and open the Mach installation directory C:\mach3. Look for an XML file with the same name as your profile, i.e. "machmill.xml".
Happy machining , Jeff Birt
Offline Alax7
  •  15 15
« Reply #12 on: June 06, 2013, 03:29:12 PM »
got it
« Reply #13 on: June 06, 2013, 05:23:43 PM »
You do not have a port number specified for the step/dir ports, see screenshot below.
Offline Alax7
  •  15 15
« Reply #14 on: June 07, 2013, 12:09:16 PM »
I changed them to port 1, still no movement.
At what point should I be able to get motor movement? The minimum settings needed once starting to set mach3 up to get the motors moving?
Offline Alax7
  •  15 15
« Reply #15 on: June 07, 2013, 10:54:32 PM »
I also set it up on my laptop and no movement either. Anybody?
« Reply #16 on: June 08, 2013, 02:17:34 AM »
What you have set in your xml, with the addition of the port values, should be enough to get movement. That assumes you have entered the correct port and pin numbers and do not need any enables for your drives or breakouts. Without knowing what hardware you have that last part is impossible to say.
If you look on the diagnostics page what does it say in the Frequency DRO?
Offline Alax7
  •  15 15
« Reply #17 on: June 09, 2013, 06:36:42 PM »
Thank you, at least I know I'm on the right track.
I have this kit by the way
http://www.automationtechnologiesinc.com/products-page/stepper-nema23-3-axis-kits/cnc-stepper-motor-3-axis-kit-3
ESS
http://www.automationtechnologiesinc.com/products-page/breakout-boards/smoothstepper-ethernet-motion-control-board-for-mach-3
Wired like this
http://www.automationtechnologiesinc.com/wp-content/uploads/downloads/2012/08/KL-4030WithC10.pdf
I did read on the mach3 manual that you can use an db25 LED tester, I guess I'll go this route to test and see if the signals get through.
If anybody comes up with anymore tips, my offer still stands
« Reply #18 on: June 09, 2013, 06:59:35 PM »
Swap your step and Dir numbers around, according to the wiring diag X Step is 2 and X Dir is 3, you have 3 and 2. You also have them the wrong way round for the other axes.
Offline Alax7
  •  15 15
« Reply #19 on: June 09, 2013, 09:35:37 PM »
Nice catch. Switched those around, still no movement.
